Cutwater28GG
- Jan 14, 2016
- seattle
- C-28
- Non-Fluid Motion Model
- Cutwater 28
- Living The Dream
Been anchored for two days (1 night). End of second day my house batteries are showing 90% capacity on the balmar
Smartguage. The solar has done well topping up the batteries
I decided to start the engine to add some battery juice for the fridge over night. Engine failed to crank
Short crank and nothing. Clearly not enough volts.
Something has dragged down the engine battery over the two days
Managed to start by crossing over the house batteries onto the engine battery
The battery is only two years old and pretty well babied for that time. I don’t think the battery is toast
I either have a really bad parasitic draw on the engine battery ( alas I didn’t note the engine batt volts before I managed to start) or.
I have a suspicion I have an issue with the acr design on the cutwater with solar
My solar panel is shaded by the radar. So as the boat swings solar charge swings from 7 amps to .5 amps depending on the shadow . This can happen every 2 minutes or so.
With the timer in the acr before it isolates could it Get the engine battery into a state when it is dragged down to match the house battery?
Even still at 90% charge on the house it’s seems to me that the engine batt should still start at that same volts.
Ideas?
Ideas?
