Contento
- Mar 12, 2018
- C-28
- FMLT2719A313
- Scooter
On my prior boat, a Valiant 42 sailboat, I would flush the main engine and genset in prep for summer, inwater, layover by closing the raw water thru hull, then inserting a fresh water garden hose into the raw water inlet strainer, turn on the fresh water, start the engine and let it run until it warmed to the point the thermostat opened and then continue to run it for 15 to 20 minutes to thoroughly flush the engine. Once the engine was running, I'd adjust the garden hose so that the flow would keep up with the engine water pump and overflow into the bilge slightly. The thru hull would be kept closed during the layover. Does anyone see a problem with doing likewise with my D3 and Maze genset? Of course careful observance of the water flow is paramount.
