Zundels
- Sep 8, 2010
- C-248 C
- FMLT2515G809
- (2009) Kya Rose
Our R25 (with Cummins 150 engine) SmartCraft reading shows the engine gear temperature and pressures not reading properly or we have something that needs immediate attention. Get these readings if the engine is hot or cold:
Gear temperature: 17925 F is this are faulty reset max temp?
Gear Pressure: 0%
Checked the fluid systems and they are full and normal.
Is there some other system I should check or is there a reset to the displays to show current and accurate gear info?
Thanks, Don
Gear Pressure: 0%
Thanks, Don
