dougandnancy
- Mar 6, 2019
- C-248 C
- FMLT2550H708
I recently discovered that one of the lag bolts securing the rear-most starboard motor mount on my boat would not tighten. Upon removal, the 2 inch 3/8" bolt appeared intact but had apparently stripped whatever it was screwed into. I assumed that there was a wooden block under the fiberglass floor, but was told that, in fact, it bolt was screwed into lead. In exploring the hole the bolt came out of with a couple of probes, it seems that there is an initial 1/2 inch of fiberglass and then nothing until beyond the length of the bolt.
What gives? I'm now wondering if whatever the bolt was mounted into has fallen away or perhaps it missed the lead during construction? All the other lag bolts are tight, but the prop shaft seems to wander at times. I am really at a loss about what to do now.
TIA,
Doug
TIA,
Doug
