I can not send a picture that would help because I have a C26 and have moved my batteries to a different location. If no one has changed the factory cables all should be marked. Engine battery, Thruster battery, House battery, Positive cable , Negative , and jumpers are all marked. If they are not marked ,simply trace back to the source. Engine battery should have a direct Yellow (Negative) lead to the engine (ground). Red (Positive) from battery to engine battery switch. If you have doubts of battery cable configuration the best way to confirm it is right is to trace the cables to their connection. Having this knowledge my come in handy in the future and possibly resolve your issue now. In doing this you may come across a poor connection ,corrosion or loose cable connection. I would also confirm battery condition fully charge and load test.
