gonzo
- Dec 11, 2010
- C-24 C SE
- fmlt2113a606
- Lara
- CF0309 TH
Hi Im new here. I just bought a 2006 Ranger 21EC.
The first thing I did was change the exhaust riser. Even though it only has 100 hours on the meter but not knowing the history, I figured I better. Ive learned tough lessons with this part. After only 4 years there were large flakes of rust falling out of it and the exhaust passage was some what restricted with chunks of rusted cast iron erupting from the walls.
Im surprised that no one is talking risers here. When this part fails it WILL destroy your entire engine. As in hydraulic locked cracked cylinder walls. Yanmar says to remove and replace annually, some say every 5 years in salt water even if flushed, and 10 years for fresh water. I plan on every 5 years here on the California coast.
It is an easy job. For the 3YM30 the part cost $160. Remove the exhaust assembly from the engine. Separating the exhaust pipe from the riser is tough. The threads are rusted together big time. I used a torch, a large vice,a piece of pipe, and a block of wood with a hammer all at the same time and voila it broke loose.
I guess most of these boats are less than 5 years old but I just thought I would pass some wisdom along seeing that no one here is talking about them. Replace your risers friends.
