jagizzi
- Apr 17, 2017
- C-242 C
- Non-Fluid Motion Model
- R-23, July 3rd delivery, yippee
- Next Ten
I am trying to get the GPS from the Garmin 7610 to the Standard Horizon radio and have the wiring diagram that seems to reference NMEA 0183 connections. Basically connecting color coded wires from the radio to the Garmin. Sounds easy, not so far.
The radio wires are pretty easy to find and color coding matches expectation. I pulled the radio and voila, there they were tie wrapped neatly waiting for a connection, so far so good.
On to the Garmin. I went into the head and lowered the fuse panel to look at the back of the Garmin, easy to see but no wires sticking out waiting for me. I pulled the panel below that and accessed great bundles of wire but couldn't trace them out given the small hatch.
I then pulled the wall in the head, still pretty easy to do and can now trace the cables on the back of the Garmin. The only likely candidate is the NMEA 2000 cable but it runs to the autopilot, I think, and is connectorized on both ends. There are no loose unconnected wires from the back of the Garmin. Where are folks making this connection?
I know that this has been done as folks talk about it, but how was it done? Any ideas out there. Is the old wiring diagram obsolete with NMEA 2000?
At a loss here and looking to see if anyone has done this already. I may be out of luck as it seems that the factory is now doing this for folks but I sure do want to have DSC call capability and the emergency call capability with broadcast coordinates.
Any one have any ideas on this?
Thanks in advance for any help.
Jim
Jim
