Hydraulicjump
- Feb 10, 2011
- C-30 CB
- FMLT2911F415
- Non-Fluid Motion Model
- Necky Looksha VII, Liquidlogic Remix, Jackson 4Fun
- La Barka (2015)
This is a lemonaide out of lemons question for those with an R-27. I was having a weak start battery problem, even though my flooded batteries are less than a year old. On advice, I replaced the start battery with a cranking battery (Interstate). In a long process not to be described here, I eventually discovered a hard-to-find, intermittent weak ground connection that was probably the source of the problem. Yes, yes, I should have load tested the start battery first. But let's not dwell on my ineptitude. There are others in my household to help with that.
So I have this extra one year old battery that is perfectly good and was thinking about adding it to the house battery bank so I can be an amp hog on the hook. I already have a switch that allows me to parallel the house and thruster, so this is icing on the amp cake. After $20 for a battery box and another $20+ for cables, and the requirement to buy a fifth battery when it comes time for a total swap, I am having false economy and sunk cost effect discussions with myself. Still, these boats are all about being comfortable and secure, and this is small change compared to filling the tank.
For those who have rationalized adding an extra battery in their R-27, where did you put it and did you run into any charging problems?
