BattleBorn
- Jul 14, 2020
- C-24 C SE
- USFMLT2138D
- TBD
Good morning everyone!
I recently purchased a 21EC and named it Knot So Fast. We love the boat! Will be posting some awesome pictures in the Emerald Green waters of the Gulf of Mexico here shortly. All of the systems on the boat worked great! The fridge was cold, the AC worked (as well as it can in the Florida heat), bow thruster and motor all worked great to UNTIL... The motor began to sputter and randomly kill itself.
It wasn't an electric problem, there was plenty of gas and we weren't in shallow water or anything. So after talking to the group and the previous owner it was suggested that I put some Diesel stabilizer in the gas tank because the boat had sat unused for quite some time prior to my purchasing it. In addition it was suggested that I change the primary and secondary fuel filters to make sure they weren't clogged. I did all of that and took the boat out again and had a couple of days with no issies.
Then after running the motor most of a day, it begun to stutter again. It seems like the motor isn't getting sufficient fuel almost like its choking. It hasn't been bad enough to kill the motor, it just drops in RPM really low for a second or two and then, thankfully, climbs back up without me touching the throttle at all. I checked all fluids, made sure the gas tank was actually full, electrics are good and filters have been changed. The only other thing I can think of is maybe the fuel filter needs to be replaced but I figured I'd ask just in case anyone else had seen this issue before. Thanks in advance for the help!!!
