Brian B
- Apr 19, 2012
- C-26
- FMLR2512L910
- Non-Fluid Motion Model
- Sold in 2021
- GANSETT RANGER (2010) Yanmar 4BY2-150
I have installed this system on the two outboard batteries. Now all I have to do is squeeze the bulb that pumps distilled water into the batteries at the correct level. Normally I would have had to pull the batteries to check them. The inboard set of batteries I can get to easy enough so I only did the outboard set.
https://www.flow-rite.com/battery-water ... /qwik-fill
I purchased from Amazon as it is cheaper.
The primer bulb is also needed and sold as a seperate kit.
