Assuming the coolant is a couple of years old, I question the benefits of any flushing...
My choice is to drain the block and radiator...
Refill with fresh...
Run engine a few minutes and shut off and drain a second time..
Refill with fresh coolant...
Done....
In a long life I have owned several businesses including auto and truck repair... Learned a lot about the predatory behavior of name brand manufacturers... Yanmar is making a huge profit on their branded coolant - I don't like being taken...
ALL antifreeze for engines is Ethylene Glycol mixed 50:50 with water... The only difference between the types is the anticorrosion and lubricant additives...
Green (traditional Prestone, etc.) colored antifreezes are considered good for 2 years / 24000 miles... It contains silicates, and other chemicals to work it's magic...
Extended Life / Long Life antifreezes contain Organic Acids for the anticorrosion p;us the usual lubricants... They can be rated as long as 5 years / 150000 miles...
I can recommend the following long life / extended life coolants as having been found excellent for use in diesel engines by diesel engine remanufacturers I dealt with...
Texaco Long Life Coolant and anti-freeze #7991 (premix is #7998, but again you are paying $3 a quart for water)
Havoline Long Life Coolant and Anti-freeze # 7994
Dex-Cool Long Life - any GM dealer or auto store
Prestone Extended Life...
Now, having said all this, I maintain a number of engines, diesel and others, and I normally use plain old green coolant and change it every two to three years (depends on the running hours - my classic tractors only run 5 to 20 hours a year so 3 years is fine)... I have not had a coolant related problem in 50+ years...
My tug is due for fresh coolant this fall... It will not be one of the organic based, long life coolants (i.e. orange color)... It will be Green... YMMV
