Hi all,
I'm having the same issue on our 2020 R29. When I hit the solenoid button on the Xintex display unit, I get the green light for the solenoid activation, but I don't hear the solenoid valve open, and I get no LPG at the stove. I've already bought a replacement solenoid valve, as ours looks pretty corroded, but before I replace the valve I'm trying to do some troubleshooting to make sure it's indeed the valve.
The Xintex manual states that the nominal current draw for the solenoid valve is 55 mA @ 12V DC, and the Maximum Current Draw is 725 mA @ 9V DC. Using my clamp amp meter, I didn't seem to get any current draw through the solenoid, as measured at either of the two conductors going to the solenoid.
The Xintex manual states that a 2 amp fuse should be installed between the Display Unit and the solenoid valve. A note on page 7 of the manual states: "Units manufactured prior to January 01, 2018 do not include the 2A fuse. A dedicated 2A fuse or breaker should be used to power the solenoid."
I followed the Solenoid Valve-to-Display Unit wiring as best I could (most of the run is within split loom), and I didn't find an in-line fuse. Does anyone know if there is indeed a 2 amp fuse installed, and if so, where it is located?
If the 2 amp fuse does in fact exist, and if it is blown, wouldn't the "Fault" LED on the Display Unit be illuminated?
Any thoughts on this would be greatly appreciated.
Thanks!
-Mike
