Force 10 Stove Not Lighting
Bosn Mate
R-29 S
FMLT2912I718
Tingira
Good Morning!
First time on the boat going thru all systems. Tried to light the stove with no luck after completing the following:
1. Attached propane bottle and opened - 100 psig+ on gauge.
2. Cooktop Oven Breaker on.
3. Pushed knob for 20 seconds - did not smell propane.
Suspect I am missing a step?????
Any help would be appreciated!!!
Mike
Did you press the Propane solenoid/valve switch? Propane will not flow into the cabin & appliances until the switch is in the on position (2 green lights will show). The switch looks like this and should be mounted somewhere near the stove:
https://www.bing.com/images/search?view ... ajaxhist=0
You were spot on - took your advice and problem solved.
Thanks for the assist!!!!
Mike
