djpcep
- Feb 19, 2009
- C-248 C
- FMLT2537J809
- Poppy
On my photo album Nos. 4, 5, & 6. I have shown my solution to flushing the engine with fresh water after a sea trip.
Engine flush 1. shows where I have inserted a 1½" equal T (nylon from Home Depot) into the feed line for the marine head. (Well above the water line).
Connected to this I have a black 1½" hose (West Marine) and run it round the back of the holding tank to the point in the back of the aft locker wher the wash-down supply exits. (Engine flush 2.) Here I cut a hole and inserted the connector I had left over from my wash-down modification. On the outside (Engine flush 3.) you can see the new brass angled wash-down connection and the old one now used for the engine flush.
Operation With the boat either in or out of the water connect a garden hose to the flush connector and leaving the sea cock open, turn on the water supply to full flow. The water should then pour out of the sea water intake under the hull.
I reckon that the sea cock should stay open to avoid pressure on the inside of the sea strainer. Closing the sea cock could blow the glass dome !!! I do not intend to try!!
Run the engine, keep the water flowing, and stop the engine before turning off the water supply.
I reckon this will work in or out of the water.
If anyone thinks that there are any probleme with this arrangement do let me know.
