Toki
- Apr 21, 2019
- C-28
- Non-Fluid Motion Model
- Tartan 30, Columbia 26
- Toki
Hey folks, R27 Classic with the factory salt water head flush system. If I want to flush fresh water through the system, say for winter layup or thorough sanitation system rinse, what's the best way to do that? Here's what I did:
1. Shut the sea water through-hull valve
2. Use the electric flush until no more water flows into the head
3. Use the shower head to pour fresh water into the head while flushing
Now the problem with this method is Step 2 takes a long time. There's much sea water upstream of the through hull in the strainer, lines, wherever.
Is there a way to disable the sea water pump to the toilet while still enabling the flush out pump? Or maybe another valve to shut off the sea water closer to the head? Or am I going about this all wrong and there's a much better way to run fresh water through the system?
