SJI Sailor
- Nov 28, 2018
- Non-Fluid Motion Model
- American Tug (formerly had C30)
I recently fixed a hot water tank leak on our 2019 C30 (will follow up on that thread separately). Now the water is back on, but the fresh water pump is clicking -- a very, very short burst -- every 5 seconds or so. Annoying!
I would suspect a leak ... except I can't find a leak, and it seems like too short of a pulse. It is something like 1/10th of a second and there is not enough activity to recharge the pressure really at all, just a momentary "pp!" that makes the intake hose jump and does not run at all. When there have been leaks in the past, it was more like, "prrrrrrp" for 1/2 to 1 second that was obviously charging the pressure.
Apart from this, the pump is mostly OK but it does seem to pulsate quite a bit more than previously, during low-flow usage.
Any ideas on where to start? The ones that come to mind to me are:
1. Could it be air in the lines? I drained the water before working on the hot water tank. OTOH, it has been this way now for 1 week, and we've pumped 1/3 a tank of water using all fixtures. And it never did this when winterizing, etc.
2. Could it be a leak that just has such a tiny pulse to recharge?
3. Could it be a defective pump, pressure sensor in the pump, or bits from the tank being emptied caught in the pump? I have a spare pump and could replace it if that seems likely.
Thanks in advance!
Thanks in advance!
