coreychamness
- Dec 30, 2013
- C-302 SC
- Tugs 'n Kisses
I can see that the screen on my water pump has white "crud" on it and I would like to clean it. When I attempted to unscrew the cover I found it too tight to remove and I was afraid I would break it if applying a tool. I noticed there was a red button and when I pushed it I was able to remove the entire screen assembly - unfortunately a gusher of water began dumping into the bilge so I immediately put it right back. Is there anything that can be done to be able to clean out the screen without draining the tank? Is it normal for the screw-on cover to be so tight?
Corey
Corey
