CaspersCruiser
- May 11, 2016
- R-27 Classic
- FMLT2709G112
- Cookie
To prepare my boat for winter storage, I changed the fuel filters on the Yanmar 4BY2-180 in my 2012 R27. The ones I removed were installed by a well-known and experienced shop in business for decades. Unfortunately, the technician way over tightened the filters and they were ridiculously difficult to get off.
The primary fuel/water separating filter eventually broke loose using a standard metal band filter wrench, but I was quite concerned that the torque I was applying to the filter was going strip out the screws holding the entire filter assembly to the side of the engine compartment.
The secondary filter was another matter entirely. The filter would not budge using the strap wrench I’ve used in the past to remove that filter. I had to find another tool.
Most readily available metal band filter wrenches have a maximum diameter that’s too small to fit the secondary filter’s 4 1/4” diameter. That’s why I used a strap wrench— it would fit around the filter. I did a “removing fuel filter” search on Tugnuts and eventually came up with mention of the Gearwrench 3 3/4” to 4 1/2” Heavy Duty Filter Wrench:
https://www.amazon.com/KD-2320-Heavy-Du ... B0002SR56W
I ordered one and went to work on the secondary filter using a 1/2” socket wrench and extension. No joy. The filter wouldn’t budge. For extra leverage, I used a breaker bar. That extra torque caused the wrench to slip on the filter. To keep the wrench from slipping, I put a strip of Skid Guard Safety Tape on the filter to give the wrench something to bite into. That worked. With maximum effort, the filter turned VERY slowly for one full turn, but it did come off. That filter was on there just stupid tight.
I hope the post title will make it appear in searches for folks dealing with removing fuel filters. The filter wrench mentioned here is worth the money and the techniques involved worked for me.
