rt11002003
- Dec 16, 2008
- C-24 C SE
- FMLT2113H314
- Loaf'N
Andrew,
This fuel issue seems to grow.
I stopped by the boat after my workout to measure, thinking about the fuel vent issue. I finally realized the fuel tank is not sitting flat. It is mounted such that aft end of the tank is sitting on the aft lip of the pan on which the batteries, fuel tank etc. are mounted. That results in the bottom of the tank not being supported except at the aft end (about a 1/4 of an inch support) and the forward end. Surely that is not correct.
I just read Shaun's post about replacing the fuel tank in his R-21. That is way more than I want to get into.
I can't see any baffles in my tank. The fuel sloshes heavily in any kind of chop. I'm not convinced Ranger has a good solution for handling fuel on the R-21.
So far: The fuel return line rubs a sharp edge of the fuel filter mount. The fuel vent line has two kinks, resulting in difficulty refueling, fuel/spray coming out the outlet vent and pressure buildup forcing fuel out the filler cap. The fuel tank is not well supported. 🙁
Should I try to move the fuel tank forward about a quarter of an inch so it is fully supported by the pan?
Gene
Gene
