Trisailor
- Jul 8, 2017
- C-28
- FMLT2720H011
- Fancy Nancy (2011 R27)
Anybody out there know a part number or the manufacturer for the fuel pickup tube on a R27? I have one that is loose and has a cross threaded fitting the shutoff connects to. I suspect this happened when the engine was changed in 2013. I would just tighten it, but that will require removal of the fuel line and it looks like the amount of rotation required to tighten the fitting in the tank will cause interference between the aft bulkhead and fuel line/shutoff valve.
