Thanks I will look 😀BB marine":3in89ckn said:As stated the fuel tank is fit nicely into the stringer system. It looks like a custom fit. The head conversion to the Air head is a very good option. This allows for removal of black tank and replacing it with a fuel tank in the 20gallon range. I elected to use a different option. This option requires Generator not installed and it is a bit labor intensive. This option took care of two issues. (1, moved 3 batteries to starboard side of the boat so it floated level when at rest. (2, made room on the port side where batteries were at to install a 22 gallon Aux/fuel polishing tank. This is a post from last year showing the project. viewtopic.php?f=24&t=10989&hilit=+fuel+tank#p75443 There are other photos of the installation in my album. I use the tank as reserve fuel for longer planned runs. It allows me to use the full capacity of my main tank and not worry about running out of fuel. With the valves positioned I transfer fuel from main tank to aux tank once the tank is full it overflows and fuel runs back to the main tank. Change valve position and it transfers fuel from aux. to main. I have a pump power switch at the dash to transfer. There is a third option, carry remote tanks. I did that the first year of cruising and it worked too.
We had "startup problems" with ours that sound similar to the above description. Caused due to liquid not separating properly. The manufacturer was very good about working with me to get it sorted out. Now it is so dry that I have to add water to it to keep it wet enough to properly compost. During our three month boating season we spend a total of about 40 nights on the hook with two adults aboard. Before we got the Airhead working right it had to be dumped once mid-season. Now it makes it through the season without the need to dump it. I leave it to compost until the following spring by which time it is not quite as unpleasant of a task.Toucan":23fzp0np said:...Since we cruised for long periods and ate a high fiber diet, the Airhead was overwhelmed with deposits that never dried or composted. When "stirring" the compost, it resembled a taffy mixing machine. Every few weeks, it was my job to scoop out the contents, which had the consistency of adobe (sticky mud reinforced with coconut fiber)... It was nicely made and might work well under other circumstances.
