Fuse for fresh water pump, R29, 2012.
Baetz
C-288 C
T2908F112
Footloose
Fuse location for the fresh water pump.
Ranger 29, 2012. Where is the fuse for the fresh water pump? I have searched the fuse blocks and haven’t been able to find it.
Many thanks,
There may be a bunch of in line fuses at one of the battery switches. There should be a label for each fuse.
Thank you for the suggestion. There are a number of well marked fuses, unfortunately none are the fresh water pump. I can’t find the fuse!
Perhaps it is wired thru a breaker switch?
Many thanks for the reply, that is exactly the situation. There is no fuse, it is wired through the breaker.
