Fuse location for underwater lights on R29
PlanetoSea
C-30 CB
FMLT2913I718
Plane To Sea
Hello factory team,
I believe the underwater lights installed on a 2018 R29CB have an inline fuse that should be somewhere along the wire run inside the boat, but I have no idea where to locate that fuse. Both of my underwater lights are now out, and I'd like to check the fuses before I take any steps to try and replace the lights. Can you let me know where those line fuses may be? Thanks!
Can't help with the inline fuse location, but FYI: my 1 year old OceanLED u/w lights were found full of seawater, which eventually shorted the PC boards. The local Boatyard said they had found other such units with same problem. Dealer said they never heard of this problem. Neither Ranger factory, Dealer nor OceanLED covered the cost. OceanLED warranty disclaimer states "...warranty will not apply unless these units are mounted flat against the transom" (R27 mounts onto trim tabs).
Hello Ranger Tug Factory...? Anyone listening on this one? Any help you can throw my way on this question? Thanks!
Our r31 has a 3 A fuse on house battery block under cockpit sink for UW lights. My port are out, Stbd OK. got to trace wire in hull and see if broken, diver says everything outside looks good.
Thanks bill46--appreciate the reply. Where is the cockpit sink on the 31? I don't have a cockpit sink, but maybe the wire run follows a similar route. Thanks!
