Fuse Question
pete s
S-250 DC
FMLT3111L718
Sveikas !
Hello RT factory and fellow "Nuts".. (BTW.. FANTASTIC Webinars !! thanks!!)
Question about my 2018 R31 CB...Luxury Edition...(so it has reverse cycle heaters rather than Webastos..)
For layup this winter... i pulled some fuses to spare the batteries as I have a canvas winter cover that blocks the solar panel... no problem.. batteries did well.. However, when I went to replace the fuses, I realized some wires were unlabeled and or different than the "Owners Manual" shows.
1): probably easy..DASH FUSE BLOCK #2: two wires labeled WEBASTO... are those just for my fore and aft Reverse Cycles??
2): the top right wire in DASH FUSE BLOCK #2 is a smaller red unlabeled wire (not "Diesel Heater" as in the operators manual picture) that I believe on my boat should be 20A, I accidentally put a 1A in which blew, and seems to be something to do with the radar since the radar would not work once it blew (I put a 20A in and all is now fine with the radar.) Is a 20A correct for that??
3): DASH BLOCK #2- small unlabeled orange wire, 3rd down on right
4): DASH BLOCK #1- 2 small red wires unlabeled, both with 7.5A fuses, last 2 on right bottom
5): DASH BLOCK #1- top lugs each side, NO wires attached, only left one has a 3A fuse in it.
6): DASH BLOCK #1- 3rd down on left, tiny red unlabeled, 1A
I understand every boat is different.. just wondering if the factory had any info for me. (by the way, bought some incredibly genius replacement fuse where a small LED lights up in the fuse that blows!!! Only slightly more $, but boy what a headache saver !!!) Thanks
Pete S.
Pete S.
Hey Pete,
I am working with our plant now to get you an answer on this, could you please send me an email so we can work on this via email? Also any pictures you can include would be a great help as well. My email is kevinlamont@rangertugs.com.
Kevin Lamont
