Fusion MS-IP700i replacement
Rcireland
C-26
FMLR2505G314
Sea Salt II
I have a Fusion MS-IP700i radio in my 2014 R25. The radio needs to be replaced and the old replacement model was the MS-UD 650 which is now no longer available. Does anyone know what the replacement for the 650 is?
I'm sorry I'm no help here. I did my replacement with the MS UD 650 and it was a true plug and play and fits the same hole beautifully. Sorry to hear it's no longer available.
I have a 2011 R-27 and replaced the stereo a couple years ago. I have newer chart plotter installed also, 8612xsv. If you still have old chart plotter, some info that follows will not apply, but mount and hole size are the same. My old stereo was a MS-CD600, which is same mount hole size as MS-IP700i. I installed a MS-RA670, works great and can control from chart plotter, which I love. The MS-770 would also work, it costs $250 more, has built in wi-fi and Apple Airplay. The MS-RA670 part number is 010-02138-00. You will also need a retrofit faceplate kit, part number 010-12829-03. Looks fine installed, basically it extends faceplate to either side, looks like part of original unit. Again I have 8612 chart plotter installed. Because this 670 stereo is not wi-fi, I connected to chart plotter via LAN cable. I also connected SiriusXM antenna, mounted where original TV antenna was removed. These cables were run behind cushions above V-berth back to stereo head unit.
Thanks for the info. Will the RA670 still work as a radio/iPod/iPhone music player with old chart plotter?
