FYI-Port of Edmonds & Yamaha Service at Jacobsen's
baz
Subject: FYI-Port of Edmonds & Yamaha Service at Jacobsen's
If you're moored at the Port of Edmonds as I am, and have a boat with a Yamaha outboard we are lucky to have Jacobsen's Marine right next door to us.
Last Sept I had my F300 serviced there and at this time also setup for my next service for Sept 18 2018 with the Service Manager - Doug Schaenherr. I learned a few weeks ago Doug had left Jacobsen's so was wondering if my Sept 2018 service appointment was still good.
Today I check this appointment and found out that it was not on the Schedule sheet. I was told to Email Kevin Danberg (the new Service Manager at service@jacobsensmarine.com) and confirm my Sept 18 2018 service with him.
If you also use Jacobsen's for your Yamaha servicing and had setup a service appointment in advance like I had, I suggest you send Email to Kevin. The servicing schedule at end of boating season can get very crowded and busy making a last minute service appointment difficult.
Just saying.... 🙂
[EDIT] These are my notes from last Sept while chatting with Doug.
1) F300 is an extremely reliable motor; failures very very rare. Technician asked me what kind of car I had. I told him it was a Volvo. He smiled and said then you know how reliable the Yamaha motor will be because it's as good as the Volvo. :lol:
2) Recommends the 9.9 Kicker motor for peace of mind; 2nd engine can be or could be a life saver. In addition, if trolling frequently it's far better to use the kicker motor rather than the trolling feature of the F300 and of course means less hours on the F300 which could cause increased maintenance frequency.
3) Motor maintenance requires the motor+boat to be out of the water, on a trailer and in the shop. You give the shop your boat key and they organize getting the boat hauled/lifted out onto trailer; they perform the service and return the boat to your slip. You pickup your key and pay for the maintenance service work.
4) Cost for hauling, use of trailer; round trip will cost $185. Labor charges are $145/hr.
5) Typical 100 hr maintenance cost around $650. If not at a 100 hr interval then yearly or can extend this to 2 yrs as required.
6) Very important to check and clean the engine fuel fine mesh filter periodically. This is the most common issue as if it clogs to any degree the motor's operation will be compromised. The Edmonds marina has non-ethanol gasoline at fuel dock and this is highly recommended.
7) The small spout of water shot out from side of motor is just to let you know the raw water cooling system is operational. The raw water is sucked up from either side above the prop bullet and some of it exhausts through a small rubber outlet on rear of cowling. The majority of the raw water is expelled through the prop shaft along with the exhaust fumes.
8) There are two large external anodes; First one above the prop and below the trim plate. It is released using a long extension (maybe 8" long) from the top. It hangs down a bit and looks like an inverted shark fin. 😉 The second one is a big 2" plate attached to base of the bolting plate on the boat's transom.
9) There are 4 pencil type anodes buried in the engine which under normal use should be good for long periods. Of course they do need checking periodically.
10) If any of the lower part of the F300 sits in the water when in full raised position then the portion in the water should be treated with hull bottom paint as growth will surely occur. This includes the motor's transom bolting plate.
11) It's best to setup a maintenance schedule with the shop as there can be a long waiting time of 2 months during busy times.
12) Using the connecter for attaching a fresh water hose for flushing the salt water from all parts of the engine takes around 5 to 10 minutes to perform. The fresh water will appear to ooze out everywhere... so don't worry. This should be done with engined stopped.
13) Combustion air is drawn in from the two horizontal slots on either side of the cowling.
14) The raw water pump's impeller is very big and should last for a good 10 years in the technician experience. Great. 🙂
$$ OUCH- I just talked with my Yamaha dealer, who is 2 miles from my house. His labor rates are $90/hr and he quoted me $225 for the 100hr service, although this is with me delivering the boat to him on my trailer. I need the 20 hr service done and he is booked out 3 weeks at this point. I will be doing it myself, it is easy enough since I have the boat on a trailer.
