The Shaft Brush was installed yesterday without too much trouble. I attach some pictures below.
1) The small length of chain was substituted with a plastic tie to allow easy removal and rotation of the Shaft Brush when engine maintenance performed. There's not too much space stern side of engine for feet placement etc.
2) The small length of green wire that came with the Shaft Brush kit was substituted with a longer 8 gauge wire to keep the resistance between stern mounted zinc and the Shaft Brush as low as possible -- besides, it also match the same gauge as used by the factory for bonding things in the engine bay. FYI -- the supplied green wire was not long enough to reach the zinc bolt on the starboard side of the transom.
3) The Shaft Brush was initially located mid point on the exposed prop shaft between the stuffing box and the engine shaft bearing housing.
Question: what type of engine prop shaft bearing is employed in the Yanmar 150 HP? Is it a ball bearing type ?.
4) One question in my mind was... could the brush cause a `screaming noise' when underway with the prop shaft turning at high RPMs. Will no doubt find out later about this, but suspect any brush noise will be completely drowned out by normal engine noise.
5) After installation completed, I started the engine and nudged it into forward gear with the boat securely tied down in my slip. The reason for doing this was to see if the brush would gravitate/move to one end or the other of the exposed prop shaft. That is, would it move toward the stuffing box or the engine prop shaft bearing. As it happened, it moved toward and contacted the engine prop shaft bearing. The adjustment to make the brush stay put is accomplished by angling the brushes via their individual fastening screws. This was done a few times and at each time I observed how the brush moved until it did not move, and remained stationary at the mid point of the exposed prop shaft. I will occasional check this over time to see if the brush moves away from the mid point. Of course, when docked and hooked to shore power the important aspect is that the brush be in solid contact with the prop shaft.
6) The 8 gauge wire connectors were properly soldered at both ends to reduce resistance. The wire was easily routed and zipped-tied in place through the engine bay and back to the long bolt holding the stern zinc.
Now, over next 6 to 12 months I will record the stock prop shaft zinc erosion rate and replacement frequency to hopefully capitalize on my investment and time/effort for doing this. I will post back here over time.
I'm still pondering over the pros & cons for installing a Galvanic Isolator. I will be speaking/discussing this with my local guru Dick Troberg here in Edmonds (he lectures on boat electrics at the Edmonds Marina) who has an enormous wealth of knowledge in these matter.
