GarryH
- Jan 15, 2019
- C-30 CB
- FMLT2932D121
- Miss Starr
I recently discovered a significant amount of moisture and damp contents in the cabinet below the galley sink. Upon further research I discovered that there was constant dripping of water from the SS sink bottom, not from pipe/hose connections or the drain. My experience is that the exterior bottom of SS sinks used in residential locations are usually sprayed with a material to both deaden sound and mitigate condensation moisture. The sink in my 2021 R-29 had not been treated accordingly. Has anyone solved this issue, presumably by coating the sink with an anti-condensation material? If so, with what material? Thank you in advance for your response.
Garry Haas
Miss Starr
R-29CB
Tierra Verde, FL
Garry Haas
Miss Starr
R-29CB
Tierra Verde, FL
