Galley water flow problem
Lyons
AB4453166
SECOND CHANCE
Our galley water flow has all most come to a stop. The head flow is great not a problem. We have tried cleaning the filter at the end of the tap and have taken the nozzle off and the water flow did not change still bad.The water pressure holds and the pump does not cycle on and off. What should we do from here ??
The best thing to do is locate the check valve under the sink and remove it. It really serves no function.
There are a few threads on this issue. After the check valve removal if there is still an issue check the connections where the water lines connect to the faucet lines. I have seen strainers in that connection that got considerably clogged. If you are having the issue on hot and cold then I suspect the check valve.
