HappyPlace,
Since you are on the East Coast, I would guess your R31 might have air conditioning. For my R31S, which has air conditioning, I installed the ProMariner ProSafe FS Galvanic Isolator - 60 Amp. Notice, I installed the 60 Amp version,
not the 30 Amp version, which I bought directly from Richard Becker at Ranger Tugs parts department. If you have air conditioning, the 60 Amp version is required on the R31 since it has two (2) 30 Amp inlets. This version works with the two (2) 30 Amp inlets, which the 30 Amp version does not. See this link for the correct version with its specs, if you have air conditioning:
http://www.defender.com/product.jsp?pat ... id=1353701
Notice that the specs state: "...Or Dual 15's, 16's, 20's Or 30's"
You do not need monitoring, since the ProMariner ProSafe FS, if it fails, fails in a fail safe mode, meaning that the ground connection to shore remains intact. In the early days of galvanic isolators, there were problems with them failing in a mode that terminated the ground to shore, hence the need for monitoring. Even today, if you do not buy one that fails in a safe mode, then a monitor is required by ABYC standards.
