Channel Surfing spends her time in brackish water, moored at a marina, plugged into shore power.
My boat came from the factory with a galvanic isolator installed. My trim tab anodes last about 6 months while the engine transom anode lasts about a year. The rudder anode I've not had to replace yet (going on 18 months) as the outboard spends most of it time out of the water.
However... I like to know what's going on, and I'm always looking for ways to improve, ways to identify a problem before something becomes a problem. Instrumentation is important to me.
I recently ran across a video on YouTube (not one of my own, though I will probably make a video about this).
I ordered, and it just arrived yesterday, a Corrosion Reference Electrode from Boatzincs dot com. It attaches to your digital volt meter, you drop the probe in the water near the underwater metals at the back of the boat, the other end of the digital volt meter attaches to the DC grounding bus on the boat. The readings it gives you will let you know the electrical hull potential. Said differently:
"Do I have enough zinc on my boat?"
"Are my shaft zincs still attached?"
"Is my bonding system working okay?"
"Are boats next to me eating my zincs?"
"Is my galvanic isolator working?"
"Is all of my electrical equipment installed correctly?"
"Do I have stray electrical currents either in my boat or at my dock?"
"Is my dock and/or marina operating at the correct corrosion potential?"
https://www.boatzincs.com/corrosion-reference-electrode-specs.html
I'll be trying this out this coming weekend down at the dock.
