sierracierra
- Jul 25, 2017
- R-21 EC
- FMLC2839C313
- Artemis
My Garmin 7212 chartplotter will not turn back on using the push-button switch. The only way I can get the chartplotter to turn on is to turn the house power switch to off for a few seconds , then turn the house power switch back on ( or disconnect the power cable from behind the unit and reconnect) and then push the push-button on the unit. The unit beeps once, I can hear the radar antenna power up and rotate for ten seconds or so then the display lights up and all appears fine.
It stays running and all functions appear to be working - all is good.
However, If I push the push-button switch to turn the chartplotter off, the unit shuts down but now I cannot turn it back on by pressing the button again. I have to cycle the house power switch again ( or power cable off/on) (which appears to "reset" the unit).
I did update the operating software from 4.50 to 5.1 but that didn't appear to make any noticeable difference.
Any hints or suggestions would be appreciated,
Glenn
Glenn
