Scuffy
- Mar 5, 2015
- C-28
- FMLT27161
- Non-Fluid Motion Model
- Float On Tandem Axle Trailer
- Tinytown
Everything was working fine until this trip. Everything works except radar. It does not show up as it used to in the combinations. I called Garmin moved the network cable to a different port on the rear of the 7212. Fuse good, power at the plug connection under the dome is good. The Ethernet plug seemed to be ok except the mast has been in the down position. It did appear to be a little wet. I gave it a shot of WD-40 blew it off reinstalled the plug. No radar showing up on the menu. Any ideas before I seek professional help?
