UVAfisherman
- Jan 22, 2021
- R-31 CB
- At Liberty
I recently sold my R27 and took possession of a used 31 CB. The prior owner had created an Active Captain account with his email address, so when I connect to the Garmin wifi, I cannot perform any updates because it lists me as a guest. The prior owner has removed all the devices from his Active Captian account on his phone, but the Garmin units still shows him as the owner and me as a guest.
I called Garmin and was surprised to get through to someone knowledgeable at customer support. They told me to disconnect both Garmin units (the main one and one on command bridge) from the NMEA network by unplugging that cable in the back of each unit. After that, perform a factory reset on the main unit, which will exorcise the prior owner's information.
I am of course terrified that the factory reset will mess up all the other connected devices, but that is, according to Garmin, what you avoid by first disconnecting the units from the NMEA.
Has anyone dealt with this issue and/or have any experience with the ramifications of the factory reset?
Thanks in advance.
Thanks in advance.
