Red Raven":1twmv388 said:
In addition to the MOB cause it is really easy to mistakenly engage the circle pattern used for fishing. On our 2014 systems you can engage the autopilot to “Follow Route” on either the Garmin or the autopilot controller. If I do not initially engage the route on the Garmin I have to use the menu button on the AP display. For some reason I have never figured out, the “Follow Route” option is not always available. In its place is the “Circle Pattern” (or similar name) option! Don’t know how many times I have (or was about to) pressed that button!
What I've learned is, when I create the route on the chart plotter, it'll ask me if I should engage the autopilot. If I say no, then I wouldn't get the "follow route" option on the autopilot. Often, when I plot my course I am not in a position to actually engage the autopilot.
What I have trained myself to do, which works every time... I plot my course on the chart plotter, it says "do you want to engage the autopilot", I always click "engage", then I immediately press "standby" on the autopilot display. Then I motor around until I get to the point I want to engage the autopilot and simply press the "follow route".
