Rocky
- Feb 20, 2017
- C-30 S
- FMTL2919K718
- Cerise
We have a 2018 R29S. Over the past few months I have had an intermittent anomaly in my autopilot. I am curious if I am the only one. Occasionally, it will engage itself (uncommanded) into “Heading Hold” mode. The only thing that is consistent is that it only happens after I have started the engine and begin to move away from the dock. Yes…the worst possible time! Trying to steer leaving the slip, only to have it try to steer back straight is a bit unnerving. Yesterday, I watched the AP display closely pulling out of the slip. When I put the boat in gear, it showed “standby” but in less than the boat length it suddenly showed “Heading Hold.” I quickly disengaged it and went on my way. My new plan will be to make sure the AP is “off” as I leave a dock until I think it is fixed. It has never done this out cruising. Once I disengage it, it does not engage itself again either.
It has happened 5 or6 times since last summer. Mostly at the slip, but it has happened at the pump out dock twice as well - not that location would have anything to do with it.
I have shut off power from the batteries a couple times. I have the latest Garmin Update (February) installed.
Reading all over the web, I can’t find any discussion about this uncommanded engagement issue.
I have an email into Garmin but I thought I would ask here if anyone had ever heard of such a thing while I wait for their reply.
Probably unrelated, but Garmin installed a new AP pump under warranty last summer, but I don’t recall it happening before that, but it may have.
Any thoughts or ideas?
Thank you!
Rocky
Thank you!
Rocky
