LMRanger
- Jul 3, 2019
- C-26
- FMLR2514J415
- Puffin
Got fed up with and the steering on my R25SC and added the Garmin Check Vale Kit. The "kit" is not what it is hyped to be, because it comes with the check valve only. You have to turn around and buy $300 worth of fittings and additional hoses.
The hardest part of the install was the purge of the system afterward. For that I had a mechanic come over with the Power Pure Jr. and he was able to purge the system with the auto pilot in factory setting to purge the pump and check vale too.
The difference it has made in the steering is more than worth the extended cost of the addition of something that Garmin and Fluid Motion should have corrected years ago.
Ralph
Ralph
