Brian B
- Apr 19, 2012
- C-26
- FMLR2512L910
- Non-Fluid Motion Model
- Sold in 2021
- GANSETT RANGER (2010) Yanmar 4BY2-150
I have the 5212 system with a model 17X antenna. The antenna failed and I replaced it with the new model 19X. The symptom was a flashing question mark on the chart screen, no satellites showed on the satellite receiving screen. I called Garmin Tech Support and worked through a few procedures and it was determined the antenna had failed. I also borrowed the antenna from another RT and that worked on the system so I was then convinced to replace the antenna The new 19x kit lists for $250.00, I was able to find one on Ebay for $99.00.
Removing the VHF wire from the radio to the backbone and connecting the antenna to that wire is an easy way to determine if the antenna or wiring failed. In the past I had the wiring fail and navigated with the antenna on the helm connected to the VHF wire. (I credit another RT owner with that fix)
