rmsbwt
- Aug 27, 2012
- C-24 C
- Non-Fluid Motion Model
- Cutwater 28
Has anyone else had any problems with the Garmin sonar unit not functioning while in water less than 5 - 6 feet deep?
If so, has anyone installed a real/true through hull transducer from any manufacturer in a Cutwater?
We are interested in the transducer installation location.
I am thinking it would be better to ask these question before drilling a 2" hole in the bottom of our boat.
Would the Cutwater factory shoot through hull transducer location (next to the shower sump in the V-berth) work for a true through hull transducer?
We have ordered the Garmin/Airmar B60 the 16 - 24 degree dead rise model.
The problem is not an install, set up or settings issue. We have spoken with Garmin and Airmar about 14 times.
Currently the Garmin 4210 is using the Airmar P79 transducer installed in the Cutwater factory location?
The Garmin tech line has said many time that the unit is not expected to operate in less than 5 feet of water.
I'm not buying this statement.
Any info. on transducer location would be appreciated.
