gas gauge reading opposite way
mike pons
darkshark
help !! 2020 cutwater 28 I took out gas gauge sender checked with ohm meter works fine. gas remaining gauge on garmin is ok, tank level on garmin and volvo penta read backwards????
Hi there Mike,
Make sure that nothing was reconnected in reverse and that all connections are good. Nothing much else, but this should get you back to normal
Cheers,
Ralf
thanks for your reply i will check all connections again
