Gelcoat scratches on hunter green hull
Pearl
C-24 C SE
Pearl
The scratches in the hunter green hull are white in appearance. My question is can I sand the scratches out or do I need to buy gel coat?
Unless the "scratches" are from something white rubbing the green hull, you're gonna need a little colored gel coat.
Charlie
I had some scratches in our red gelcoat and called Andrew or Kenny for advice. With a proper sand paper, rubbing compound, glaze and waxing you might be able to bring the color back, I was able to. However if what you're describing is the white underneath your green gelcoat Charlie's advice stands. It's a least worth a call to the factory guys.
Jim F
