Gen raw water pump seized
Scuba Too
R-29 CB
Blue Honu
The raw water pump stopped on my gen. I figured it was the impeller, but when I pulled the pump I realized it had seized (the was also a broken tine on the impeller). It looks like there’s lubrication ports on the housing. Should I have been lubricating it? And if so, with what? The manual doesn’t mention this. The gen has just about 100 hrs over 6 years, so lightly used.
Which model geb do you have?
It’s a NextGen UCM 1-3.5 with a Jabsco raw water pump.
How old is the generator? Is it possible it was sitting for a long time without being used?
Did you take the belt off and try to spin just the water pump?
If it still doesn't turn I would take the pump off and rebuild or replace it.
-martin610
