Jerold Geisenheimer
- May 26, 2010
- C-288 C
- FMLt2919c909
- Joint Venture
First I would like to thank you guys/gals who helped me solve those technical problems that invariably plaque new boat owners. To recap, primeing the A/C units after haul outs is essential, the bilge pump constantly running was solved by eliminating the back flow preventer, the frquent loss of the prop anode was corrected by a large fender washer between the anode and fastener, battery drain was eliminated by disconnecting the negative ground during long periods of inactivity. Some of my own modifications: a flush out connection between strainer and intake valve, replacement of the plastic washdown hose outlet with a brass fitting and fitting a rubber sleve over the cutlass bearing to prevent splash. Finally, one question, staing of the interior running down the walls is becoming a more noticeable problem. Any easy solution? Thanks. Jerry Geisenheimer
