ethanbarnett
- May 11, 2015
- C-30 S
- LIBERTY
While on the hook and using the inverter generously I have found that not even running the generator will charge the house bank. The inverter charger switch would be on inverter mode. Now while underway in inverter mode the light on the remote panel will switch from inverter green to charging green. How do I charge the House bank when the charger/generator is evidently not triggering the ACRs? Only solution I have found is to run the boat around using my alternator to charge the batteries. Why doesn't running the generator charge my House batteries when they are low, say sub 12.5 when on the hook? Solution?
Thanks.
Thanks.
