Larry1030
- Mar 14, 2019
- C-28
- FMLT2728I819
- MS Saleway
Recently the electric raw water control valve for the generator on my 2019 R27OB failed. The generator would run for a few minutes but would shut down because of a high temperature situation. It was determined that the valve did open to allow raw water in to cool the unit. My mechanic recommended replacing the automatic valve with a manual valve which I open and close manually each time I start or shut down the generator. As anyone else experienced this problem and is there any issue with the manual valve set up. All is working fine with the manual valve.
