ACUSTIS,
Once again thank you , and don't worry I have plenty of questions.... but promise not to take advantage or bombard you with them all at once.
Along the lines of the higher horse power engine for a little more speed at cruise range .
Has Ranger found any mods to go slightly faster ? My prop is pretty dinged from all of the floating debri (mostly wood ) in the river where I boat,and I was thinking of experimenting with a different prop , has the factory had any luck with pitch or diameter change ?
There is a guy we know in the marina here who pulled his motor out of a 21ec and offered to sell it to me for a spare ,your not going to believe what he is planning to do . He chopped the floor up and is making mounts in the engine bed for an older 4 cyl. mercriuser . I think he said it was a 140hp.The really trick thing he said is fabricating a custom transmission for a test to hook to the shaft, and the engine well looked like he did a really nice job when we saw it.
He has a few go fast deep v's here also , and one they race.
I am giong to ask if I can take a picture and post it here ,you have to see it , it seems like a lot of work and not a practial set up ,but he is serious about it . They are looking for something crazy like around a 30mph top speed :shock:
His friends showed us pictures of the 21 with two good sized outboards mounted on the back and said that was the first test, you know how racers are ... always trying to make things go faster even if they are not designed to do so.
They also showed me where they modified and cut the keel and ran strakes on the bottom. I can't say it's my cup of tea , but I can't wait to see how it comes out
Another quick question is do you have any tips for changing the prop with the boat in the water in case of an emergency,I have dove under the boat to try and see what it would be like ,and it seems possible. I keep a small honda 2hp just in case I need to get out of the channel if power fails and it works ,slow but it works.
