Gregg
- Nov 23, 2008
- C-24 C SE
- Lady Gwenythe
Hello Everyone,
I have a 2008 R21ec with the Guest 6 amp charger wired to the house battery when on power at the slip. I usually leave it plugged in at the slip for a most times I'm away. So I notcied the other day that the house battery was very hot and so was the charger. As it turned out, the house battery was cooked. I replaced the house battery and everything seems to be now behaving normally again. My suspicion is that the Guest charger has been overcharging (or incorrectly charging) that battery to point that it finally failed. Has anyone else had a similar experience? The battery was relatively new, (about a year old) and I generally put light loads on the house battery when in use (mainly just electonics). Does anyone have a charger that thev've had a good history with and can recommend?
Gregg
Gregg
