Hydraulicjump
- Feb 10, 2011
- C-30 CB
- FMLT2911F415
- Non-Fluid Motion Model
- Necky Looksha VII, Liquidlogic Remix, Jackson 4Fun
- La Barka (2015)
Perhaps, since it is Halloween, I should just say my boat is haunted.
Last week when coming back to the dock to put the boat on the trailer the low oil pressure alarm went off and there was very low pressure (below 10 psi; I have around 30 psi at idle with a warm engine). I turned off the engine and drifted to the dock and tied up. First thing, I checked the engine compartment expecting to see oil all over the place. Nope, clean as a whistle. I had also checked the oil before departure: dead in the middle of the port side dipstick.
Now how to get the boat onto the EZ Loader....so I started it back up, got 25 psi at idle, and idled it up to the trailer. When I pushed it to 2000+ to move it up onto the trailer the pressure crashed and I shut it down, winching the rest of the way.
Andrew and Kenny suggested that I check the engine ground, since this causes problems for oil pressure alarms. The internet was pretty useful, as was this site, indicating a likely failed oil pressure sending unit. My sissy mechanic said he wouldn't work on it because it probably involved the need to read the codes and then futz with the ECU which he says he can't do. Knotflying was a great help and suggested that I put an ohm meter on the sending device to see if it is changing resistance with rpm, and to then put a mechanical gauge on to see that I actually have oil pressure. The Yanmar repair manual (if you don't have this, it is worth downloading) basically pointed the finger at the sending unit.
Went out there today armed with all the necessaries: multimeter, jumper cable to bypass the engine ground, hose to shove into the strainer (boat's on a trailer), beer...
Wouldn't you know it, the thing ran fine. Checked the oil: perfect. Started it up and oil pressure jumped all the way to 80 psi. As the engine warmed it slowly came down. I ran the rpm up and down multiple times and the pressure adjusted with it (no need to bust out the meter). At about 115-120 degrees the idle pressure settled down to its normal reading. I did not try to get it up to its normal running temperature of 189 since that would have taken forever without the ability to put a load on the engine.
So now what? I went back and found the grounding buss had modest corrosion on it. I cleaned that up. Cleaned the ground contact with the engine (no corrosion at all). Same for the batteries. What I DIDN'T do was remove the beauty covers and clean the contacts on the sending unit. I will do that next time I guess. I also need to get it up to full running temp to see what the pressure reads.
So, I wonder when this "ghost" will reappear. Boo!
Happy Halloween
Jeff
Happy Halloween
Jeff
