Has anyone removed a 21 ec eyebrow? (for painting)
lproulx
C-24 C SE
Red Owl
I am having my boat painted, and would like to have the eyebrow done also. I assume the running lights can be simply detached and moved aside. Having done that, do you just remove the visible screws? Is there any sealer or bonding agent to deal with? I suppose they might be able to just mask around it, but it would might be a better job if it could be removed.
Larry
Larry
Hey Larry,
They are screwed in with the screws you see but we also seal those screws and use seal to keep in place so there should be quite a bit of seal to remove and clean up. Maybe easier in the long run to mask off, also if you don't have any leaks now it would be nice to know that you won't have any leaks as it wasn't removed. Hope this helps!!
