DocJoe
- Nov 18, 2022
- C-242 C
- FMLT2302E819
- Bonus Round
My fuel tank brackets are not in a correct, or safe, position.
I can reach the aft brackets to loosen and then reposition, but I cannot reach the forward brackets.
Is there an access panel to be able to get to the screws holding the nylon brackets in place?
Or, if no access panel, then how do I get to these nylon brackets to loosen them so I can properly position them to hold the fuel tank safely in place?
It appears that the fuel tank has shifted position to starboard, and the port nylon brackets are now pressing into the sides of the fuel tank. This is a very unsafe condition inasmuch as boat movement could rupture the fuel tank ... and then boom!!
The boat only has 58 total operating hours, so this appears to be a design flaw. I have some good ideas for a re-design, but I first have to get to the nylon brackets to loosen them.
I have removed the cushions from the port storage (AKA The Cave) in the main cabin area that is directly over the fuel tank, and I do see horizontal panels (decking) that are screwed into place, but not sure if I remove those panels that I will gain access to the fuel tank brackets. Is this a point of access to the nylon fuel tank brackets?
I appreciate any and all advice and suggestions.
Thank you, Joe
Thank you, Joe
